CANON IR ADV C 5030 i Insert Drum Unit black,magenta yellow
  • doktor
    • 215
    The customer moved the machine to another location.After connection machine an error occurred Insert Drum Unit black,magenta, yellow.Before I go to the customer I would like to hear your opinion.
    Thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: CANON IR ADV C 5030 i Insert Drum Unit black,magenta yellow
    Hi Doc!
    The error occurred during the transport, so I conclude that you will correct the problem if you reseat itb and drums.
    • doktor
      • 215
      HI
      The problem was condensation.The machine was moved from a cold to a warm room.When the machine is warming up to room temperature It works normally.
