Doing color mismatch fail
  • Peter Sim
    • Sep 2008
    • 445
    Hi all
    Need help.
    Canon iR Adv C5035.
    Printing color is double image but B/w was ok.
    Attach here with PG6 and PG10 sample :
    Doing the Auto color mismatch was problem ,it show "Auto color mismatch was stopped,start correction again,if error code continue to occur,
    contact your service representative."
    Already change Registration sensor and SL1 unit and reseat all 4 drum unit and developer unit,but the problem still same.
    i also follow this links to rectify the problem but still the same:IR adv C5051i Color Registration Problem
    Hope someone can shed some light on it.
    Thank you in advance.
  • 20 year tech
    • May 2014
    • 577
    Re: Doing color mismatch fail
    Check your patch read sensor shutter it is likely broken and the sensor cant read the patches on the itb belt
    • Brian8506
      • 1664
      I had that on a C2225 and had to clean the patch sensors
      • tech28
        • Jun 2013
        • 434
        What 20 year vet said, shutter, also have had problem, there is a bulletin on this. Part that breaks is about 10 bucks from PR.
        • Northwestservice
          • Jan 2011
          • 140
          had same problem in a remote gold mine. the dust there was so fine and abrasive that I had to clean the shutter rail and the solenoid every visit because the shutter would stick in various places....
          • hidius
            • Jun 2015
            • 128
            looking at your examples .. i suspect its the CK laser unit. you can test this out by swapping the 2 laser units around and see if theres a change in the pg10 test. or you can grab a laser unit from a different machine and swap it with the CK laser.
            • Peter Sim
              • Sep 2008
              • 445
              Already swap the laser unit,but the problem persist .Will try to look into the registration sensor again and the shutter
              • hidius
                • Jun 2015
                • 128
                when you swapped the lasers around did the problem moved to from black and cyan to magenta and yellow if you do a PG10 test page ?
                • Peter Sim
                  • Sep 2008
                  • 445
                  Before i swap the laser ,the PG 10 is like this.
                  • Peter Sim
                    • Sep 2008
                    • 445
                    After taking back the machine to repair , change the laser unit (C/K) ,the problem solved .Thanks again for the good infos
