error code E000020-0000
  • juventuss
    • Aug 2025
    [Error Code] error code E000020-0000
    Hello,
    I have a Canon IR2270
    recently it shows the error code E000020-0000,
    The Drum keep turning in vain until it shows this error code
    Pls anybody here cauld help me with some instructions or pieces of advice.
  • hutmah
    • Sep 2017
    • 19
    Re: error code E000020-0000
    Have you checked the dev? This code shows when toner is detected in the sub hopper but not in the developing unit.
    • Cave Man
      • Mar 2011
      • 7
      Originally posted by juventuss
      Hello,
      This is a toner adding error. You need to remove the sub hopper and dismantle it. That is the assembly that the toner bottle goes into. Sometimes a bit breaks off the valve at the top of the toner bottle and gets stuck in the toner feed mechanism. This prevents the toner adding motor from turning. Takes a bit of time but its the only way to make sure.
      • Brian8506
        • 1665
        Hello,
        Or just replace the toner hopper
