Hi friends and happy new year to you. I wanted support for activating a PS license on a Canon ADV 4225i copier. thank you and good after you.
canon 4225i
Re: canon 4225i
imageRUNNER ADVANCE Series
Installing Printer Kit License from RUI
1. From the RUI Main Screen, select Settings/Registration and login as administrator.
2. Select License/Others.
3. Select Register/Update Software.
4. Browse to the location of the license file, and click Next>. The license file with be loaded and a message to restart the printer will appear.
Or look under
Device Configuration to register PS LICENSE
Or,
April 1, 2011
All imageRUNNER ADVANCE Series
Using the Remote User Interface, (RUI), to Register a Licensed Product Online.
In order to make the registration process easier, the RUI may be used as a means to streamline the registration process for the installation of licensed kits for a device.
In order for this process to work properly it will be necessary for the imageRUNNER device to have a network connection that supports internet access since part of this registration process will require "online" access.
1. Launch the RUI and select Settings / Registration.
2. Look in the left margin for "License / Other".
3. Make the selection for "Register / Update Software"
4. Now select the "Delivered Installation" option.
5. Enter the License Access Number for the product which is being registered and select next. At this point in the process the device will go "online" to register the machine serial number to the License Access Number and license the specific product for the device. Follow the prompts in order to complete the process with a machine reboot as the last step.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: canon 4225i
Or look under
Or,
April 1, 2011
Thanks for the support, I was able to install it perfectly. God bless you.IZIANComment
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
