E732 0021 Adv 6255
  • roho
    • Mar 2009
    • 844
    [Error Code] E732 0021 Adv 6255
    After replacing the waste toner drive and a constant E013 errors, I know get E732 0021 errors. I get the reader initializing and the adf sees paper in the tray, (so I believe I have 24 volts present) but there is nothing listed under service mode for the reader or feeder version number. Any ideas? TIA!
  • NorthW
    • Jul 2017
    • 55
    Re: E732 0021 Adv 6255
    Most likely a connector has been left unplugged, double check where you had your hands last.
    • Rachid.Akli
      • Oct 2011
      • 595
      Dear Sir,
      I have the same issue ( E732-0021) on my IRAdv8205 Pro. Please, can you share if you have any solution?
      Best regards.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        Originally posted by Rachid.Akli
        Dear Sir,
        Best regards.
        doubt you will get one since it's been 2 years w/ no reply
        • COPIERTEC ASSOCIATES
          • Aug 2011
          • 279
          This being a reader communication error,and the mere fact that you replaced waste toner unit,re-trace the connections to the DC board .There is a possibility that some connections are not properly connected .
          2 Critically look at the communication harness connection from the DCboard to Reader board since the 24v is already present at the reader boarding meaning signal voltages not being detected by the DC board.
            Hi it could be a problem with this pcb
            • 27th
              • Mar 2019
              • 9
              Hello Rachid,
              If it can help you, had the same error on an iRAC52xx. The power supply assembly was faulty
              Swapped it with a working one and everything is fine now.
              In my specific case, the reader controller pcb ass'y burnt down.
              Had to swap it too.
              I think the customer had some sort of 'electricity outburst' or something like that..
              Hope it'll help you and good luck !
              • Rachid.Akli
                • Oct 2011
                • 595
                Dear Sir,
                Best regards.
                Dear all,
                A french proverbe says "It is better late than never".
                The above error code E732-0021 may be displayed after opening and pulling the upper rear cover of the machine. This opertaion may disconnect the HDMi reader cable in the machine side. That is what happened with my machine.
                I hope this will help.
