Canon ir Adv 8105 Quick menu not working
  • amitlama_78
    • Oct 2009
    • 62
    Hello
    Request for help
    My quick menu has stopped working......
    I tried in the service mode but its not working.
    If I do all data Initialization will it solve my problem.
    and if i do so is there anything that i have to take care.
    Regards
  • amitlama_78
    • Oct 2009
    • 62
    Re: Canon ir Adv 8105 Quick menu not working
    Any One please suggestion required
    • teckat
      • 16083
      Warning:Initialize All Data
      Note: all customer data will be lost.
      • teckat
        • 16083
        To enable the Quick Menu button on the control panel, set UI-CUSTM to a 1 in service mode (Level 2) under COPIER > OPTION > DSPLY-SW.
        • amitlama_78
          • Oct 2009
          • 62
          i DID THE PARTICULAR PROCESS BUT THAT'S NOT WORKING.
          • amitlama_78
            • Oct 2009
            • 62
            What all data will lost....?
            Will I be able to use the copier machine after data initilization.
            mine is used machine and if i do data initilization what will happen?
            • teckat
              • 16083
              Level 2: COPIER > OPTION > DSPLY-SW > UI-CUSTM
              0: deactivate the Quick Menu
              key------------power off/on Printer-----------is Quick Menu Deactivated ???????
              1: activate the Quick Menu key
              are u trained on model ?????????????
              Do not do a "Initialize All Data"
              "settings/registration" > logging in > management settings > data management > initialize all data/settings.
              All user settings and (unfortunately) data are returned to default.
              what is on your User Data Print out ???
              • amitlama_78
                • Oct 2009
                • 62
                I did the what u said but still not working
                • teckat
                  • 16083
                  guess u have two other options---------
                  this site assumes no responsibility on your procedures--- these are only suggestions /
                  If you are not sure what condition printer will be in after a performance----do not go forth
                  MMI Clear-----------------make sure to print out P Print settings
                  MMI = Clear of user mode setting value
                  Details = To clear the user mode setting values (excluding values for Control Panel, common settings, and FAX).
                  - Common Settings
                  - Timer Settings
                  - Adjustment/Cleaning
                  - Report Settings
                  - System Settings
                  - Copy Settings
                  - Communications Settings
                  - Printer Settings
                  Use case = When clearing various setting values of user mode
                  Adj/set/operate method
                  1) Select the item, and then press OK key.
                  2) Turn OFF/ON the main power switch.
                  Caution = The setting value is cleared after the main power switch is turned OFF/ON.
                  or
