IRC2620N
  • bomberi
    • 107
    IRC2620N
    Hello!
    I've a canon IRC262ON copier with only please wait on the display, it will not pass all moment.
    So i try to download the firmware but i see that i have not the firmware of this copier not the same with the IRC3200N.
    Can some one help me with the firmware of this copier IRC2620N? Thanks for all helps.
  • teckat
    • 16083
    Re: IRC2620N
    Originally posted by bomberi
    Hello!
    iRC3200 Firmware is the same for all in series
    3220,2620.
    Does printer say please wait when trying to print
    How old are Drums ? Old drums cause please wait symptoms in this series.
    'Please Wait' message and the imageRUNNER stays in initial rotation. ??
    Check to see if the Fuser unit is coming up to temperature.
    Then check to see if the drum unit(s)are not past the life expectancy.Replace the drum unit(s) if needed.
    Remove boot Rom -clean end _reseat.
    Remove memory- clean end_ reseat.
    Remove network board reseat.
    • bomberi
      • 107
      Re: IRC2620N
      3220,2620.
      Thank you for answer, i do all this but no result, so i will try to see if i can use the 3200n firmware.
