how to repair drum ir7095
  • zigzeg025
    • Mar 2015
    • 2
  • kuby
    • Oct 2007
    • 1410
    Re: how to repair drum ir7095
    Looking like the cleaning unit is leaking at the seal at the back of the unit.
    • Northwestservice
      • Jan 2011
      • 140
      so what have you done ?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5017
        If the dots are repeated can be damaged drum due to the proximity or spark of the corona.
        • tinnyjay
          • Oct 2009
          • 663
          Originally posted by zigzeg025
          [ATTACH=CONFIG]38605[/ATTACH]
          I've cleaned mine with special powder and i found the drum is demaged.
          You're look the same.
          Time to change drum i think.
          "Who loves the roses,must also bear thumbs"
          • zigzeg025
            • Mar 2015
            • 2
            Thank you for all advised.
            • Brian8506
              • 1666
              Did you rewire the corona units?
