Developer Unveiling Developer Out - VP 7000
  • Adaltro Bar
    • Jul 2025
    [Misc] Developer Unveiling Developer Out - VP 7000
    Can anyone help, I have a VP 7000, 4 cylinders, 4 developers, 4 grids and 4 new corona wires, developer throwing machine outside, started in black and now in yellow, I changed the UR from black by a used one that had here and did the same defect.
    WhatsApp Image 2018-01-25 at 15.44.35.jpgWhatsApp Image 2018-01-25 at 15.44.36.jpg
  • teckat
    • 16083
    Re: Developer Unveiling Developer Out - VP 7000
    [ATTACH=CONFIG]38685[/ATTACH][ATTACH=CONFIG]38686[/ATTACH]
    Check if Mylar seals for the cleaning lamps and the preconditioning lamps are damaged
    Check Drum Seals
    Check all Laser Connections
    Starter / Toner Spills from the Developer Assemblies
    Spill.jpgsee attach pdf
    • Adaltro Bar
      Troquei os fios de corona do black e do yellow e o black o revelador, e ao poucos foi normalizando. Parou de jogar pra fora.
      I replaced the black and yellow corona wires and the black the developer, and gradually became standardized. He stopped playing for.
