multiple toner motor errors canon c7055
  • chrisio
    • Jul 2012
    • 104
    Hi.
    After repairing the one way gear on the back of the cyan hopper I am now getting multiple error codes relating to each hopper they are
    E025-0302
    E025-0202
    E025-0102
    We reset the code, cycle the machine and another pops up. all wiring etc has been checked it will print maybe 1-3 pages before the error happens and there is no pattern to the error codes. Could it be something as simple as impacted toner and vacuuming out the hoppers from the front will rectify it of have we done anything when rebuilding the machine?
    Chris
  • teckat
    • 16083
    Re: multiple toner motor errors canon c7055
    Originally posted by chrisio
    Hi.
    E025-0302
    E025-0202
    E025-0102
    Chris
    Check
    You can mistakely swap the two harnesses when reattaching.
    The Toner Feed Screw Rotation Sensor and the Hopper Toner Level Sensor are the two sensors.
    It is important to note that the Toner Feed Screw Rotation Sensor has 3 wires and the Hopper Toner Level Sensor has 4.
    As for the technician that experienced this, he stated that the connector easily plugged in to each sensor.
    The E025 0x02 refers to the Toner Feed Screw Rotation error. Below shows the two sensor harnesses.
    E025-0102 / 0202 / 0302 / 0402 Codes Are Occurring at Random Times.
    The E025-0x02 is defined as: The toner rotation sensor cannot detect the rotation of the toner supply screw.
    Workaround :
    In this case, replacing the hopper driver board board corrected the issue.
    The part number for the hopper driver board is FM3-9573-000.
    • dan7777
      • Dec 2012
      • 680
      Hi.
      E025-0302
      E025-0202
      E025-0102
      Chris
      Most likely you will have to take it out again. I have had to replace the black hopper twice after replacing the one way gears. Sometimes you will find other broken one way gears when you go to replace the problem one. Taking out the toner may help. That is one big pain to fix. Last time I replaced the color hopper with the problem one, there was another gear in front that broke.
      • chrisio
        • Jul 2012
        • 104
        Funny you should say that - we had the same problem with the black hopper but taking that out and then reinstalling has cured that problem and it will print black all day long now - however ask for colour and then the fun starts.
        I am not looking forward to taking it all apart again that's for certain!
        • chrisio
          • Jul 2012
          • 104
          Originally posted by teckat
          Check
          Workaround :
          That's very much for that. I don't think it's the harnesses as we didn't unplug anything as we ended up not swapping the cyan hopper as the fault was clearly the one way gear (famous last words) the drive board looks to be promising however I'm loathed to take a punt on it. Could it still be the drive board if I'm not getting a problem with the black hopper?
          Chris
          • khattab.al.masry
            • 212
            Check
            Workaround :
            Mr:Teckat you really technical engineer amazing.
            really I respect your help and knowledge.
            great greetings for you Mr:Teckat.
            Sent from my SM-J700H using Tapatalk
            • chrisio
              • Jul 2012
              • 104
              Ok. Sorry to drag this one up again! in an effort to avoid taking out the hoppers again I found a brand new motor driver board for much cheapness and installed, closed the machine up and the same thing happened! however I cleared the codes and tried again this time with the door open so I could watch for anything funky and its now working - printed off several hundred colour copies where before it would error after about 5. It seems there is a problem within the harness - would this be feasible - and if so does anyone have the part numbers for the two harnesses that go to the hoppers?
              Cheers
              Chris
