Canon Pixma mp 490
  • hectorsa
    • Mar 2011
    • 6
    [Error Code] Canon Pixma mp 490
    Hello there, im new here so sorry in advance for any mistakes I may or may not make. I have a customers Pixma MP490 with a waste ink counter full, I cannot seem to get the Canon program to reset it, please help !.
    Thanks in advance
  • teckat
    • 16084
    Re: Canon Pixma mp 490
    Thanks in advance
    Caution
    if you reset the counters,,,and do not take the printer to a shop and have the pads replaced,,, the printer WILL leak ink over time
    • hectorsa
      • Mar 2011
      • 6
      Thanks for the reply, yes I am aware as I have 35 years in the biz, the plate and service station has been cleaned. I also realize how the post reads, I need the software! Not that I could not get it to work!! Sorry for the "mencia moment"!
      • teckat
        • 16084
        what program ??----u mean the Service Tool
        1. Make sure the printer is turned off.-----remove plug from outlet
        2. Press and hold the Resume button (triangle inside a circle) ---while holding> plug back into outlet
        3. Whilst it is held down, hold down the Power button. The green led light should come on.
        4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
        5. Release the Power button.
        6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
        7. Turn off the printer and then turn it on again
        • hectorsa
          • Mar 2011
          • 6
          Yup the service tool. This particular printer cannot be reset that way according to the service manual, I get it into service mode and then it just idles for the service tool commands.
          • teckat
            • 16084
            Isn't the tool in M490 folder ?
            Setting the MP490 back to default settings
            Canon Knowledge Base - Setting the MP490 back to default settings
