IR 1310 Blank Page
  • misterchris214
    IR 1310 Blank Page
    Hi Guys, Working on IR1310 , it makes one copy fine then feeds another blank sheet all the way thru to exit tray then say's to remove jam.
    I replaced pick up cam & solenoid for possible double feed fault still have problem.
    Any ideas?
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    these idiot machines can say paper size is not that what is in the cassette check this
    fix is put a shim under the swithces on the size detect plate works a treat
