Adv C5240 not printing
  • repeatcopiers
    • Sep 2008
    • 591
    I have an Adv C5240 with only 59k copies in the field that suddenly stopped printing and scanning. We connected direct to a computer bypassing the network and still nothing. We've cleared out everything, started from scratch, still nothing. It copies and faxes fine but no print or scan. Is the Main Controller 1 the only thing I need to look at or am I missing something? Thanks in advance for any help.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4961
    Re: Adv C5240 not printing
    Did you try with Controller System Error Diagnosis Tool?
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • repeatcopiers
      • Sep 2008
      • 591
      We ran the controller diagnosis and both showed OK
      • kuby
        • Oct 2007
        • 1344
        "We've cleared out everything" does this mean the MMI too? Have you tried reloading the firmware/software?
        • repeatcopiers
          • Sep 2008
          • 591
          Sorry, we did the MMI clear but did not reload firmware, someone from a Canon dealer said the firmware shouldn't affect the print function.
          • zoraldinho
            • Mar 2008
            • 4961
            ● Boot System Error Diagnosis Tool (Turn ON the Main Power Supply Switch while pressing the Control Panel Power SupplySwitch.)
            • Main Controller PCB 1 side
            • Control Panel
            • All-night Power Supply, Non-all-night Power Supply
            Controller System Error Diagnosis Tool (Turn ON the Main Power Supply Switch while pressing the numeric keys '2' and '4'simultaneously.)
            <Main Controller PCB 1, SDRAM, TPM PCB, FLASH Memory
            PCB, PCI Expansion PCB (option)>
            • Main Controller PCB 2 side <Main Controller PCB 2, SDRAM (J11/J13), SDRAM (P),
            Memory PCB, Open I/F PCB (option), HDD>
            • repeatcopiers
              • Sep 2008
              • 591
              We ran both of these and they resulted in OK. Could it still be possible the Main Controller 1 is bad? Every feature, except Print and Scan, work fine. They didn't have any power surge that they are aware of and they do have it on a strong surge protector.
              • repeatcopiers
                • Sep 2008
                • 591
                Update, Hytec sent me another Main Controller 1, still doesn't print but now it gives a message on the bottom of the screen saying Competing IP address on Network and we know there is nothing in the office with this IP address, we tried several other IP addresses with the same result. The copier won't go out and find an IP address using DHCP. And when we assigned an IP address, we couldn't PING it. We connected it directly to a computer using a crossover cable to bypass their network and still the same problem. Also, when we put their original Main Cont 1 in, it does not give us the message about competing address but everything else is the same. Any ideas?
                • teckat
                  • 16092
                  Try a "Initialize All Data"
                  Warning:
                  Initializing all data will initialize many factory settings, the back up data sheet located on the very last page of the Service Manual lists all that is cleared when performing this function, print out a user data list 1st!
                  To Initialize All Data: You must be logged in as administrator > Select Settings Registration > Management Settings > Data Management > Initialize All Settings > select yes, this will roboot the machine and a new screen will appear explaining "do not cut power" and a 20 minute time allocation bar
                  • repeatcopiers
                    • Sep 2008
                    • 591
                    Update: The problem was on their network side. Of course that was our first question and we were told their IT people checked everything on their side and the problem was with the copier
                    • teckat
                      • 16092
                      this won't be the last time u have issues with IT People
                      • kuby
                        • Oct 2007
                        • 1344
                        Network side:
                        Yes been down that road. We trouble shot a machine and told the customer that they needed to check their network and their guy came unglued. Their IT guy came out ranting and saying that it cannot be MY NETWORK. So we tested the machine further and hooked up a laptop up to the copier and it printed OK. Again I told them that there is something on their network causing the problem or a bad cable, and then again with the ranting about how he has been doing this for X number of years. Finally traced it down to a bad cable when he guy went to lunch and showed the owner and he agreed that was the problem. So no matter how GOOD an IT guy thinks he is, things can go wrong with THEIR network. Just saying.
                        • zoraldinho
                          • Mar 2008
                          • 4961
                          Something's not right here.
                          "We connected direct to a computer bypassing the network and still nothing"
                          • repeatcopiers
                            • Sep 2008
                            • 591
                            You are right, I questioned my tech about this too. He assures me he tried that. I don't have any answers except maybe it was a bad day.
