Adding an Firmware to SST
+ More Options
Posts
  • oxzz
    • Sep 2017
    • 39
    [Misc] Adding an Firmware to SST
    hello, i have bought an Firmware for IR ADV 6075, but i got nothing when adding them to SST V4.81E
    here my step:
    1. i add the folder where i save the firmware, but in the left panel they have RED font, what is this mean?
    2. after that, i back to home menu, still nothing on Model List
    3. when i try add the firmware again, they have show on left panel, but still nothing in the Mode List
    any idea about this?
  • teckat
    • 16083
    Re: Adding an Firmware to SST
    here my step:
    [ATTACH=CONFIG]38849[/ATTACH]
    [ATTACH=CONFIG]38848[/ATTACH]
    [ATTACH=CONFIG]38850[/ATTACH]
    Go to location of downloaded zip file (do not unzip it) just copy and past into the SST FILES Folder location
    C:\Canon File Folder\SST System Software Folder\SST Files
    Now create a folder called
    iA6075_V2_v51.01.01
    Unzip the
    SST_iA6075_V2_v51.01.01
    file into this folder
    Then open SST --select register> open the C:\Canon File Folder\SST System Software Folder\SST Files
    Scroll to the SST_iA6075_V2 51.01.01> highlight to SEARCH > then register
    For some reason this firmware will not normally unzip directly into Canon File Folder\SST System Software Folder\SST Files for SST to recognize/// without creating that folder,
    • oxzz
      • Sep 2017
      • 39
      iA6075_V2_v51.01.01
      Unzip the
      [ATTACH=CONFIG]38858[/ATTACH]
      still same result,
      the Left panel with RED font i got .
      can you share the SST V4.74 ? i want to try using different SST,
      i have try adding other firmware like IR ADV 40xx, still got same result.
      • teckat
        • 16083
        Make sure u have installed only one version of SST on laptop/PC.
        Never seen red fonts in that left side menu.
        When u open the 6075 firmware folder do u see all the listed firmware in it ??
        • teckat
          • 16083
          Your pic shows 74 registered files and a OK in menu ?
          • oxzz
            • Sep 2017
            • 39
            yes, i see it all .
            i am sure i only have SST 4.81Er
            yes the pic shows 74 registered firmware and OK menu, after i click OK the SST back to Home Menu.
            • teckat
              • 16083
              yes, i see it all .
              uninstall the SST in Windows > then go into folder C:\Canon File Folder\Service Support Tool Folder and Re-install it.
              Re-open SST
              then go select >
              1.Delete Firmware
              2.Select the 6075 firmware
              3.Check all boxes
              4.Select Remove
              5.Then select REMOVED CONFIRMED BOX on lower right menu
              6.Then select OK
              Now go and try to Register the 6075
