Canon IR 1710 iF Fuser
  • yormets
    • May 2009
    • 336
    Are there any sleeves or rollers available for one of these fusers. I have one putting a line down the page most of the time. All I can find reference to is a whole new unit.
  • yormets
    • May 2009
    • 336
    Re: Canon IR 1710 iF Fuser
    Wrong Model number 1730iF
    • dan7777
      • Dec 2012
      • 680
      On a 1730 no sleeve. Try and take it apart and you will find out why. It is not made to replace the rollers. Order the assembly.
      • yormets
        • May 2009
        • 336
        Thanks for the info. Guess I have to try and find one at a reasonable cost. This one only has 80K on it.
        • dan7777
          • Dec 2012
          • 680
          • yormets
            • May 2009
            • 336
            This one has a line right down the middle. The sleeve shows nothing. Trying to purchase a new replacement from Alibaba....then I will take it apart and see what happened.
            • dan7777
              • Dec 2012
              • 680
              I run the fuser cleaning mode and it shows fuser problems if it is not solid black. Drums can show thin lines. The one I took apart I could only tell after I got fixing film out. Shining flashlight on it I could not notice anything. I have 20 or more of these machines. Some in filthy plants and run well.
