Irac 7055 E061-004
  • arctic373
    • Jun 2017
    • 3
    Irac 7055 E061-004
    HELLO ALL :
    I have canon IRC ADVANCE 7055 : have E000061-004
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Irac 7055 E061-004
    What have you done so far? Did you clean dust proof glass?
    • jamal121
      • 10
      Laser power shortage error
      At the time of measurement of 8 bright section potential
      VI at potential control, the grid bias Vgrid is more than
      100 V at least at one point.
      Dirt is applied to the dust prevention glass.
      Laser is not applied correctly.
      1. Clean the dust prevention glass.
      2. Check the connection of the laser scanner unit.
      (Connection of the connector, Shorting, Wire caught by
      parts)
      3. Replace the parts.
      Laser scanner unit (Bk)
      Laser interface PCB
      • arctic373
        • Jun 2017
        • 3
        Hello, the problem began with error E025-0402 , i replaced the black hopper unit and after that the error came up. (I cleaned the dust proof glass).
        • CopierTechofOmens
          Agitating Artificer
          • 268
          you dingled the drum contacts. Just spent 2 days tracking that down. Used a spring hook to stand them up
          sigpic
