Canon IR ADV C9060 PRO - Margin not even on all sides
  • Cmp4you
    • Oct 2016
    • 37
    Hello,
    as I was trying to print brochures with our Canon IR ADV C9060 PRO, I noticed, that the print margin is not even on all sides of the paper. Some sides have 3mm and some have 4.5 to 5mm. In have uploaded a picture of a demonstration print, where you can also see that the duplex alignment also isn't correct, even though I have done a paper tray alignment right before the print (also checked "paper tray alignment" in the print settings). Furthermore, I uploaded a file where I have written down the measured margins of the sides. The difference of .5 or 1 mm makes it hard for cutting. Is there a way to align the print properly or adjust the tray?
    Would really appreciate your help!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5011
    Re: Canon IR ADV C9060 PRO - Margin not even on all sides
    Reading material
    Adjusting Lead Edge Alignment - Canon imageRUNNER ADVANCE 6075/6065/6055 e-Manual
    • Cmp4you
      • Oct 2016
      • 37
      Thank you! I am going to try this out very shortly!
      • Cmp4you
        • Oct 2016
        • 37
        So, I have been trying it for the past hour, but the result is 0. I did everything accordingly, but if I put for e.g. +8 it then goes to the opposite of the mark (-8 -->16 steps). And if I change the value of the front side (with the 1) then the back also slightly changes.
        Is there anything else I can do or am I doing something wrong here?
        • teckat
          • 16083
          Print Driver ??
          or from what applications ?
          • Cmp4you
            • Oct 2016
            • 37
            Originally posted by teckat
            Print Driver ??
            Printing from the latest Fiery RIP Driver (Imagepass A1). Gonna have to try it with the inbuild PCL6 driver to see if it is the software.
            Printing out of Adobe Acrobat Pro with Fiery drivers.
            • zoraldinho
              • Mar 2008
              • 5011
              I check Print options on imagepass H1.
              • Cmp4you
                • Oct 2016
                • 37
                [ATTACH=CONFIG]38936[/ATTACH]
                I have also seen this in my printer options, but the offset differs from first to last page of print. I just had to print a brochure for a client and the x-offset was 0mm at the beginning and 2mm at the 20th brochure.
                • zoraldinho
                  • Mar 2008
                  • 5011
                  Now I get it!
                  We solve this problem ones, but I do not remember how.
                  • Cmp4you
                    • Oct 2016
                    • 37
                    Now I get it!
                    Bro! You need to remember it! <3
