IR ADV C5045 skewing
  • Harry
    • 228
    Need a little help from may friends!
    Have a ADV skewing image from all drawers like the example is there an ajust for this can not find anything in the service manual
    thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IR ADV C5045 skewing
    You will not fix this with settings.I would start with the ITB belt. Probably belt swinging.Visually inspect belt when rotating.Also you can make a force stop and check image on drums.If you get false image it's laser issue.If image is ok on drums but not on ITB,replace itb
    There is a possibility of laser units also.
    • roho
      • Mar 2009
      • 844
      Doubt lasers as it is all colors. Seems like a paperfeed issue to me, check the main right door for something askew. Try the bypass tray and see if it is better, has to be a common paper path for the trays. You could also confirm by checking the image on the ITB, run a pg 10 on 11/17 and stop it, if the image is straight on the belt it will be a paper feed issue.
      • Harry
        • 228
        check also from bypass it is the same from all papertrays
        thank you at all
