Canon iR ADV 8085
  • aco.bk
    • Sep 2012
    • 130
    Canon iR ADV 8085
    iR throwing error e005-001 for a few days.(Fixing solenoid cables pinched before 2 months ago,replaced fuse 1,5A)
    Came up yesterday and error displayed again.First I was disconnect Finisher and reader.When disconnect reader you need to disable readerr in service mode.When I was go to service mode noticed that all info (green ,,i,,button) displaying Japanese language.
    symbols.jpgThat was strange to me and I turn off machine and connect again reader( without finisher) and machine turned on without error code.Try to print counter list and machine is operating normally.After that I am again turned off machine and connect finisher.Again machine is working fine without error and without any service works,and all info pages in service mode was back to english.
    Technicians before me also try for a few days to reset the error without success.I m very confused because ,,I did not do anything,,and machine boot up without error code.
    WHAT WAS the problem???
    All cables from fixing web solenoid checked,it s ok.
    Outlets checked, 225V when machine working.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4955
    Re: Canon iR ADV 8085
    Interesting! Try to reseat connectors from all pcb drivers and check fuse on power supply and AC driver.
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • COPIERTEC ASSOCIATES
      • Aug 2011
      • 275
      Error 005 is fixing web error,did you try to check connection to the sensor flag of the web?
      If so,under service mode,go to COUNTER>MISC>WEB>,and clear using C on the panel.The counter for the web will get back to zero.Proceed to clear error under FUNCTION>CLEAR>ERR>OK.After switch OFF and ON the machine.
