Ir adv 6255
  • wassem
    • Aug 2012
    • 166
    Ir adv 6255
    Hi every body
    i have canon IR adv 6255 its panel hanging all the time
    i changed the whole control panel and the main controller 1 with no change
    any suggestion i will be appreciated
    thanks in advane
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ir adv 6255
    Try replacing the HDD and reloading the software (format, then upgrade overwrite all).
    That fixed a 62xx that I had with a very slow responding control panel just recently.
    The HDD on Canon's appears to hold the machines O/S, so it's pretty critical that the HDD is in good read and write health.
    [EDIT]
    There is also a bulletin for a modified CPU PCB inside the control panel as well (FM4-9880-000).
    I've changed a couple on the C52xx range to fix a freezing control panel / unresponsive touch panel.
    Not changed one on a 62xx yet, but it is worth mentioning as well.
    • Canuck
      Tech Specialist
      • 1713
      Re: Ir adv 6255
      You probably put in a panel with old style Control Panel Pcb again. Order modified pcb and upgrade firmware
      • Canuck
        Tech Specialist
        • 1713
        Re: Ir adv 6255
        Part number is FM1-U976 for improved Control Panel PCB
        • wassem
          • Aug 2012
          • 166
          Re: Ir adv 6255
          that exactly what happened
          i tried another panel and it has worked
          thanks everybody
          • Canuck
            Tech Specialist
            • 1713
            Re: Ir adv 6255
            thanks everybody
            I would order the new pcb. The old ones act up eventually. Ive replaced a few on 400/500,52xx,22xx,42xx and 62xx also
