ir3235 scanning problem
  • kstan268
    • Apr 2012
    • 85
    I had a Ir3235 machine when doing send to email there is a blue straight line appear ..i understand that whenever a dirty stick on the small copy board glass you will get a black line in result ..but in this case a blue half inch line.. it seen first time see this problem for me...need everyone help thank you
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: ir3235 scanning problem
    How's scan from glass?
    Check in service mode:
    COPIER > FUNCTION > CCD > CCD-ADJ and press [OK]."OK!" will be displayed on the screen when auto adjustment is completed.
    When "NG" is displayed,
    Replace:
    FM4-0589-000 CCD CABLE UNIT
    FM4-0588-000 CARRIAGE UNIT
    • kstan268
      • Apr 2012
      • 85
      Replace:
      Scanning from DADF
      • teckat
        • 16083
        Originally posted by kstan268
        Scanning from DADF
        Did u clean the Slit Glass ?
        Paper dust build up on glass will cause a line or lines.
        After cleaning the slit glass, install two-sided tape (purchased locally) on the DADF-U1 Feed Guide FL2-9935-000.
        The tape will act as a dust collector tape and prevent the slit glass from being contaminated too quickly.
        • kstan268
          • Apr 2012
          • 85
          I thought when slit glass dirty ..the result will be a black line appear ..but in my case it appear in blue line!!
          • dan7777
            • Dec 2012
            • 680
            Might be a color scanner? You may need to replace the scanner unit if it is still there after cleaning the scan glass and scanner. I have had to replace several of those. The line was smaller, maybe a quarter of an inch.
            • kstan268
              • Apr 2012
              • 85
              May i know is the line is black or colour??
              • teckat
                • 16083
                is line in same place all times ?
                did u searchlight inspect that slit glass ?
                post a picture of your BLUE line
                • zoraldinho
                  • Mar 2008
                  • 5007
                  Scanning from DADF
                  If I took so much time for your problem, I expect a more complete answer.
                  Adjustment is NG or OK?
                  • Brian8506
                    • 1664
                    It's a color scanner. The line is coming from the slit glass. If you scan or copy from adf do you get the line? if you run an internal print do you get the line. If your answers are yes and no, its on the glass
