Canon IR1730 line on Bottom of Copy/Print
  • doug
    • Dec 2011
    • 198
    Hi Guys,
    I have an IR1730IF that has line on bottom of copy...changed drum, developing unit and only has line when receiving a fax or print. What can this be?
    Thanking all of you in advance.
    Doug
  • mosey1100
    • Mar 2009
    • 143
    Re: Canon IR1730 line on Bottom of Copy/Print
    Did you check laser unit to see if anything blocking it causing line, or check fixing unit
    Sent from my iPad using Tapatalk
