irc3180 no display
+ More Options
Posts
  • ps/pcl
    TECH SPECIALIST
    • Jun 2008
    • 35
    irc3180 no display
    irc3180 no display
    checked RAM and controlpanel working good
    but m/c initialize the scanner and fixing and paper tray lifts
    only power LED is on.but no display
    pls help
  • BLITZKREAGG
    no display
    Product : imageRUNNER C2880/ C3380 / C2880i / C3380i Title : No power with green LED indicator on. Problem :
    New machine install with the status bar stopping about 3mm on the control panel display.
    Solution :
    Remove memory expansion DDR-SDRAM from slot J1002 on main controller pcb.
    Memory expansion could be bad or the wrong size memory module. ImagePASS memory upgrade will fit in this expansion slot and is the wrong size for the machine.
