Canon ir 2318
  • Orion2010
    • Jun 2015
    • 176
    Canon ir 2318
    Hello to everyone, i have two problems with canon ir 2318.
    1. After i have make the frist copy, appear a message (load correct paper) i make the configuration in A4 but the message appear again. After i move the cassette and put it again the frist copy its ok but after the message appear again.
    2. Seconds problem is with images which appears move it ( displaced it. Any idea??
  • teckat
    • 16092
    Re: Canon ir 2318
    [ATTACH=CONFIG]39042[/ATTACH][ATTACH=CONFIG]39041[/ATTACH]
    Remove cassette, turn upside down, and shake it,
    see if small white plastic gear falls out.
    They break of it's plastic post.
    This will cause slide alignment to move when u push in cassette, will miss reads paper size.
    Look here for pics, scroll down in link
    canon cassette broken guide gear bins on base
