ir adv 5035
  • wassem
    • Aug 2012
    • 166
    ir adv 5035
    hi everybody
    i have canon ir adv 5035
    it suddenly appeared close front cover massage and close right door
    after that it given e227-0001 and e227-0101
    i checked the sensors and switches of front door and right door
    i tried to disconnect the reader unit
    the errors disappeared but the massages still
    any suggestions pls
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: ir adv 5035
    One of the switches is bad or even power supply.
    • guitar9199
      • Sep 2016
      • 1100
      Re: ir adv 5035
      Power supply (24V) error
      Description 24V port error when the power is turned ON
      Remedy
      1. Turn OFF and then ON the power.
      2. Check the connection between Reader and Printer, and
      check that the Cable is not open-circuit.
      3. Check the 24V port of the Reader Controller PCB and DF
      Driver PCB.
      4. Check the power supply and Relay PCB on the Printer
      side.
      5. Replace the Reader Controller PCB and DF Driver PCB.
      Since you already disconnected the ADF, my money would be on the Reader Controller PCB.
      FM4-3014-000 -Duplex Image Reader B1
      FM3-7613-000 -Color Image Reader B1/B2
