IR ADV 6255 E748-2024
  • oxzz
    • Sep 2017
    • 39
    any idea about this code?
  • teckat
    • 16092
    Re: IR ADV 6255 E748-2024
    E748-2024 is described in the service manual as Main Controller 2 access errors, and suggests re-seating, or the possible replacement of Main Controller 1 or 2.
    Check If the copier will go into 2 & 8, download mode. If yes try flashing the software. If the software is unsuccessful, try holding down 2 & 4, to display the Box Checker screen. This may help isolate the failing component. If this too is unsuccessful, try unplugging the HDD, and powering up the copier.
    If E602 is displayed, there is a good possibility of the Main Controller 1 causing the failure.
    It has also been found in some cases that if the HDD is unplugged, and the copier powered up, it may point to the Flash PCB and the copier may display an E748 error code.
    In this particular case, the copier displayed an E602 when it was booted with the HDD unplugged. Replacement of Main Controller 1 resolved the
    E748-2024 error code.
    u could also try to
    Reseating the DDR2-SDRAM on Main controller 2
    • oxzz
      • Sep 2017
      • 39
      u could also try to
      first i try the download mode is fine, format HDD perfect, copying files from usb perfect, when installing its give e748-2024 again
      second, i try unplug the HDD, its getting e602-0001
      third, i try to access Box Checker, but still the machine can't access it, still get e748-2024
      last try to replace the Main Controller 2 with other machine, i got e748-2012.
      then i try reinstalling system software, problem solved.
      thank you sir .
      • teckat
        • 16092
        thank you sir .
        Good Luck !!!
        point to note
        Counter PCBs and SATA Flash PCBs are no longer available for purchase.
        E350 / E355 Error Codes:
        E748 Error Codes:
        *NOTE 1: For any of these error codes, do not swap any PCB's from any other machine. Doing so may render both machines unrecoverable.
        *NOTE 2: Do not use any of the User Mode or Service Mode clears when encountering these error codes.
        Executing the Service Mode or User Mode clears may render the machine unrecoverable.
