importing/exporting address book
  • Qball
    • Jun 2013
    • 127
    [Misc] importing/exporting address book
    Hey, it's been forever since I workied on Canon. I need to pull the address books from a iR C2020 and iR C5030 and push them to a couple of Kyocera 406ci. What utility do I need to use to pull from the Canons and where can I get it? I went to usa.canon.com but I'm not sure what I need.
    Thanks.
    Mike
  • craigster
    • Apr 2016
    • 201
    Re: importing/exporting address book
    There is a program that is called ABK to CSV. go to you tube and search abk to csv canon and you will see what I mean. I have used it works for address book. Good luck
    • JPiek
      • Oct 2014
      • 435
      Not sure what format the Kyocera needs, but you can export the adressbook of the canon in it's webinterface :
      Goto interface - login as admin -> settings/registatration -> Data management -> Import/Export -> Adress lists -> Export : Then select 1 to 10
      Format is :
      subdbid: 1
      dn: 201
      uuid:
      cn:
      cnread:
      mailaddress:
      enablepartial: false
      accesscode: 0
      protocol: smtp
      objectclass: top
      objectclass: extensibleobject
      objectclass: email
      Johan
