IR5050 reset unit 1
  • RHodg57
    • Dec 2013
    • 191
    IR5050 reset unit 1
    This IR5050 when started up it stays on reservation copies can be made for a long time. If I attempt
    to make a copy it says suspended. When I open up the front door it says Reset Unit 1. So I do that and
    close the door and it says the same thing. I did find a piece of paper in the connector at the back of
    unit 1 and removed it and made sure there weren't others. I tried a good working Unit 1 and it did the
    same thing. I went after wiring and checked to make sure that SW 7 had continuity to the DC Controller
    connector. I checked in I/O mode and found that the fixing/feeder present bit would not change and shows
    the Unit one not present. I checked the connectors on the copier that the unit 1 slides into and I don't see any
    bent pins. Is there anything else would make the thing say reset unit 1?
  • guitar9199
    • Sep 2016
    • 1100
    Re: IR5050 reset unit 1
    I've seen cases where a small scrap of paper either on the machine side, or the Unit 1 side blocks the connection making the machine think the unit isn't set properly. I'd remove the entire unit, and get a look deep inside the inner connector. I even had to remove one rear connector completely to get all the paper scraps out.
    For some reason, end users think that if Unit 1 is difficult to close, the solution is to just slam it harder!!
    ...go figure....
    • RHodg57
      • Dec 2013
      • 191
      ...go figure....
      I have seen that many times also. I have it far apart enough to almost get my head inside. I air cleaned
      the connectors. It never gets away from saying Reservation copies can be made. When I open the front door it
      says Reset unit 1 and close the cover. When I close the cover the screen still says reset unit 1 and close covers.
      I tested the front door switch and it seem to be okay. I would have to order a D.C. Controller just wanted to hear other possibilities. Thanks for the advice.
      If you think of anything else let me know.
      • RHodg57
        • Dec 2013
        • 191
        Okay...found another thread on here that is exactly what I am getting.
        I did search for FU18 on here after discovering
        that fuse was blown on the DC Controller and found that.
        Thanks for that thread Teckat!
        • guitar9199
          • Sep 2016
          • 1100
          You may want to check the connector frames for cracks. There's also an additional connector at the rear of the Unit 1 frame that might have paper in it as well. Also I saw on the Canon support forum where the microswitch for the handle on Unit 1 was defective, and if I remember correctly, Unit 1 has a control/driver board too! Otherwise...yeah, DCON may be your culprit.
          • Riviera
            • Sep 2016
            • 66
            I had same issue a couple times. The green locking handle for unit 1 has a micro switch under it. That will cause that problem if broke or loose.
            • kstan268
              • Apr 2012
              • 85
              Just want to know from you that after replace FU18 solve all the problem you had ??
              • RHodg57
                • Dec 2013
                • 191
                I swapped DC Controllers with an exchange from Nationwide Repair. It solved the problem. Before I did that I did quite a bit
                of wiring work making sure something wasn't shorted to another wire or to ground. I clipped off and replaced the wire ties
                on the harness on the fixing feeder assembly as a precaution. I am guessing the fuse blew because of paper jammed into
                the connectors.
                All I have left to chase is an annoying clicking noise that is coming from the fixing area. The gears are not broken or cracked.
                Happens mostly at low speed rotation. I can't get it to do it rotating the motor by hand.
                • kstan268
                  • Apr 2012
                  • 85
                  the connectors.
                  It might be the solenoid that turn the WEB roller
                  • NorthW
                    • Jul 2017
                    • 55
                    Can I ask if its a creaking noise/sound while in standby?
                    The fuser roller bushings will be the culprit, need to put some of that magic fuser grease under and around them.
                    • RHodg57
                      • Dec 2013
                      • 191
                      There was no rotation at all. Just the message Suspended then Reinsert Unit #1 when the door was opened. I have had those machines give error codes before because of paper stuck in the connectors. Never had one blow a fuse because of that. I remember that they used to blow fuses on the DC board due to a bad toner motor but never due to stuck paper.
                      • RHodg57
                        • Dec 2013
                        • 191
                        Well after a little over 2 weeks of working the copier is again saying reset unit #1. The fuse FU18 on the DC Controller is
                        blown again. There was no paper stuck in the connecters on the Unit 1 or on the connectors on the copier.
