Canon ir C2030 Error Code
  • craigo
    • Nov 2016
    • 11
    Code E000021-0120
    Starts during warm-up with clicking noise.
    Receded all for Drum units and it's still getting code.
    Originally came here for service call of poor copy quality.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Canon ir C2030 Error Code
    Possible cause: The screw is not rotating due to failure in the
    coupling between the main body and the Developing Assembly,
    or the value of ATR Sensor (M) (UN40) failed to be read due to
    an electrical trouble.
    1. Remove the Drum Unit (M) and check no damage. (Replace
    the Drum Unit (M) if defective)
    **(This is your likely culprit!! Check the drive gear on the rear of the Magenta drum to make sure it's not cracked!!)**
    2. Lift the pressure lever after the Drum Unit (M) is pushed all
    the way in.
    3. Check failure of the harness between the Drum Unit (M) and
    the DC Controller PCB (UN09/J25) (trapped cable, open circuit,
    connector disconnection)
    4.Check the Drum Unit Relay PCB (M) (UN27) (Soil/ deformation/
    damage)
    5. Check the Drum Unit Memory PCB (M) (UN31) (Soil/
    damage)
    6.Replace the Drum Unit (M)
    7. Replace the DC Controller PCB (UN09).
    8. Replace the Main Drive Unit
    • JPiek
      • Oct 2014
      • 435
      Probably a coupling problem if it makes a clicking noise... To check, boot with front cover open and push in the cover sensor. touch the M Drum, you'll feel it when it's clicking/jumping over the coupling...
      I Hope it's the drum itself... replacing the main drive unit is quite a hassle...
      Johan
