C5035 toner level
  • repeatcopiers
    • Sep 2008
    • 591
    C5035 toner level
    Does this model not tell you the toner levels? All I can find is Toner-OK.
  • ReproKev
    • 273
    Re: C5035 toner level
    If you have a Fiery attached you can go into the PS print driver (from the print screen, not the printer properties screen) and the levels are listed on one of the last tabs. I know you can do that for sure on the c7000's, I think it's the same on the c5000's.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5019
      Directly from the panel you can't i believe. Only masages for empty toner.
      • teckat
        • 16083
        Toner Levels
        Check in RUI
        • Canuck
          Tech Specialist
          • 1713
          Yes RUI is the best bet. These machines don't measure toner level in the cartridge. When the sub-hopper senses low toner, it rotates the bottle. When it rotates it for a while and doesn't sense toner in the sub,it assumes bottle is empty. RUI uses a video count estimate I believe
