E025-0410 / iR-ADV C70xx
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    [Error Code] E025-0410 / iR-ADV C70xx
    I had a 'cracking' one to fix today.
    E025-0410
    Toner container sealing/release holder shift cam HP sensor timeout (Bk) error
    -HP sensor of release holder shift cam cannot detect within specified period of time.
    Code:
    1. Check the connection of the toner container drive motor (M7) harness. (Check whether the wire is not caught by parts).
    Check the connection with the hopper driver PCB.
    Motor side: J7107, J8041 PCB side: J1370
    2. Check the connection between the release holder shift cam HP sensor (PS8) and the hopper driver PCB.
    Sensor side: J7139, J8040 PCB side: J1340
    3. Clean and replace the toner feed screw rotation sensor.
    4. Replace the hopper/stirring supply motor.
    5. Replace the hopper unit.
    *Replace the complete hopper unit if it proves difficult to identify the root cause.
    *To clear the error: COPIER > FUNCTION > CLEAR > ERR
    Hopefully these pics will help someone else.
  • roho
    • Mar 2009
    • 844
    Re: E025-0410 / iR-ADV C70xx
    Thanks for the pics, I have replaced these assemblies before for squeaks and noise, I will be looking there if I see that error code.
    • teckat
      • 16092
      E025-0410
      Code:
      Who said
      MacGyver has retired 📎
      • Canuck
        Tech Specialist
        • 1711
        Been here many times on these...replacing cracked one-way gear inside the hopper assembly. I can change the gear on the color hoppers without removing the hopper..You just have the black out in your pic. Yellow is lots of fun... JOB SECURITY..lol
        • ReproKev
          • 258
          I've replaced that gear many times and keep them in my car stock. I'd love to know how to replace the gear on the three color hoppers without taking the triple hopper assembly out. Can you give details?
          • khattab.al.masry
            • 212
            I'd love to know how to replace the gear on the three color hoppers without taking the triple hopper assembly out. Can you give details?[/QUOTE]
            Yes that amazing.
            How?
            Sent from my SM-J700H using Tapatalk
            • CanonSco
              Man About Town
              • Jul 2010
              • 368
              Last ones I have done were yellow. Fun.
              Sent from my SM-N950F using Tapatalk
              Yes, I am a nerd.
              Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
