Hey,
I just bought a used c5180. it was not tested and looks to have been sitting for a long time. i got it fired up and so far it has turned on and sort of works.
Im having print quality issues.
The colors are all misaligned sometimes its worse than other times. And also the transfer belt has some roller marks where it must have been sitting in the same place for a while. and im thinking this is causing it to slip some.
Im going to disassemble the transfer belt assembly and clean it. as the inside is quite dusty with toner as its made some rough bumps during moving.
Im also having issues getting into the print settings with the attached fiery. it seems to be booting fine. (Fiery was removed prior to rough moves) but upon selecting print settings it gives a message about if this could take time and to check the connections if this takes long. sometimes it switches to please wait. but never goes into a menu. so i cant print to it yet.
Im hoping to get this thing working well.
