Help with IRA C7260 Network setup
  • QC91
    • Oct 2016
    • 91
    [Misc] Help with IRA C7260 Network setup
    Hi, we have IRA C7260 with imagePASS-A2 we can't find any of the TCP-IP address, we have ethernet plug into the LAN on the imagePASS-A2 and have patch cable coming from the imagePASS-A2 to the LAN on the 7260 we also tried to directly Plug the RJ-45 on the IRA 7260 but can't get any IP address I will attach some screenshots printout any help would be appreciated
    7260.pdf
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Help with IRA C7260 Network setup
    LAN cable into rip.
    Cross cable rip to copier.
    In service mode set attached rip.(COPIER > OPTION > INT-FACE > IMGโ€“CONT) to 3.
    Go to printer settings.
    • QC91
      • Oct 2016
      • 91
      Hi, Thanks for the reply, I have everything set up in your Instructions but still can't get to IP address here are some photos
      • nicko6113
        • Mar 2018
        • 34
        there should be a setting under printer settings. because there is an imagepass you have to set the ip address there.
        • QC91
          • Oct 2016
          • 91
          Hi, see the setting for the network but it does not show the ethernet driver setting I only see this
          • nicko6113
            • Mar 2018
            • 34
            do you have a menu for printers that's not in the system menu? on my C5180 there is a setting under a printers tab.
            • QC91
              • Oct 2016
              • 91
              Hi, nicko6113 do you have a photo of the menu? on C7260, I did the following (Settings/Registration). Press [Preferences]. Press [Network]. Press [Confirm Network Connection Set. Changes]. Press [On] [OK]. but there is no "Ethernet Driver Settings" I only see this in the photo
              • QC91
                • Oct 2016
                • 91
                is there a way to log in via USB to see if the network settings can be changed?
                • zoraldinho
                  • Mar 2008
                  • 5018
                  [ATTACH=CONFIG]39216[/ATTACH][ATTACH=CONFIG]39217[/ATTACH]
                  • QC91
                    • Oct 2016
                    • 91
                    Hi, Thanks, I have never setup Fiery, I see there are 2 dip switches should they be set to 1? IMG_20180323_143023.jpg
                    • nicko6113
                      • Mar 2018
                      • 34
                      Try under settings, printer preferences, utility? I have not worked with this one and am guessing. But it's oddly not under network settings as it's a "print server" so it's under printer settings. Somewhere.
                      • QC91
                        • Oct 2016
                        • 91
                        Hi, thanks, I see SERVER-7AD5 1.02 put the password Fiery.1 does not work
                        • nicko6113
                          • Mar 2018
                          • 34
                          Did you try with F or f in fiery?
                          • QC91
                            • Oct 2016
                            • 91
                            Hi, F
                            • nicko6113
                              • Mar 2018
                              • 34
                              Try with a little f. When does it prompt for the password?
