E075-0103
  • Taggerung08
    • Sep 2014
    • 60
    [Error Code] E075-0103
    I have a Canon Imagerunner Advance C5250 with the E075-0103, (ITB traveled forward towards front of the machine).
    I don't see anything broken or out of place on the ITB assy. like a broken arm or bushings.
    Is it necessary to replace the ITB Assy?
    • 16083
    Re: E075-0103
    see att
    • Taggerung08
      • Sep 2014
      • 60
      Re: E075-0103
      Originally posted by teckat
      see att
      Thanks,
      Any chance you have this doc the TSP refers to? "FM1-K348-010 Replacement Procedure.pdf"
        • 16083
        Re: E075-0103
        Thanks,
        Dropbox - FM1-K348-010 Replacement Procedure.pdf
        Or here
        Image Runner advance c5035
        • JPiek
          • Oct 2014
          • 435
          Re: E075-0103
          Tip : You can use a marble to level the copier after repair (hint allready given here), if you don't have one : use the ball of an old mouse
          Johan
          • Clement5
            Re: E075-0103
            Hello
            you dont have to replace ITB text me on clementmuneza2016@gmail.com
            I will tell you how to easly fix it.
            I have fixed more than 100 Canon IR C50xx C52xx with E075-0103 error code
