IRC3080 Dead, no green light
  • RHodg57
    • Dec 2013
    • 191
    Have never had one of these machines be completed dead. What is the most common problem that had been encountered
    to cause this. I am checking voltages. The on off switch is okay. The breaker is okay. They didn't make these boards easy
    to access.
  • teckat
    • 16083
    Re: IRC3080 Dead, no green light
    to access.
    OK*
    so u have no control panel, no rotation, no heat, no green light
    U have AC In put. past the breaker ?
    U have DC Out put ?_DC output ?
    • teckat
      • 16083
      OK*
      If u have rotation, & none of the others>
      look into DC DRIVER
      • RHodg57
        • Dec 2013
        • 191
        Originally posted by teckat
        OK*
        look into DC DRIVER
        I had AC voltages but no DC anywhere. Nothing was rotating. Fans were not running. Turns out it was the all night power supply that was bad. Never changed one before. Thanks for the response.
        • teckat
          • 16083
          Welcome, forgot about that all 🌙 supply,
          • RHodg57
            • Dec 2013
            • 191
            Welcome, forgot about that all �� supply,
            Also known as the All Day Power Supply...lol...The manual doesn't really go into
            any detail about it. Only that it's there. Apparently it was drawing down everything
            else.
            • teckat
              • 16083
              else.
              Canon Expects Techs To >>
