IR ADV 6065 E315-0540
  • oxzz
    • Sep 2017
    • 39
    [Error Code] IR ADV 6065 E315-0540
    after i replace HDD, i got this error .
    any idea about this error code ?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5012
    Re: IR ADV 6065 E315-0540
    Hi,
    Are you a Tech or user? Did you install new firmware? If answer is yes then try with "Initialize All Data/Settings"
    • teckat
      • 16083
      E315 -0540 JPEG decode error.
      Description: This error occurs when images buffered in the HDD or memory were corrupted when performing image processing.
      JPEG decode is used when handling color (or gray) images. Therefore, the error does not occur for normal copy or PDL print. But it may occur with SEND.
      Try Holding down 2&4 while booting machine and see if the Box Checker comes up OK ??
      The troubleshooting procedures as per the manual follow:
      1. Turn OFF and then ON the power. If it is not recovered or it occurs frequently, perform the following measures.
      2. Format the HDD. If it is not recovered, replace the HDD.
      3. Replace the memory on the Main Controller 2 (DDR2- SDRAM).
      4. Replace the Main Controller PCB 2.Troubleshooting in the book was followed.
      However, please note, in this particular incident the procedures in the manual did not resolve the problem. Note the solution below.
      Solution :
      Cleared HDD sectors
      CHK-TYPE 6 is the APL_SEND sector.
      In this case, the technician cleared sectors 20 thru 0 one at a time.
      In SERVICE MODE > FUNCTION > SYSTEM > CHK TYPE to chose the sectors, then OK
      Highlight CLEAR then OK
      Repeat and power cycle when finished.
      Note : Clearing all HDD will erase image data. Mailbox data will also be erased.
