blank LCD screen IR7200
  • gmamadog
    • Jan 2011
    • 7
    [Misc] blank LCD screen IR7200
    The touchscreen (display) is blank on my canon ir7200. i can still print to the machine and copy (using a template over the blank display i can still select features and lets me use as a copier). not sure what i should be looking at to troubleshoot??
  • teckat
    • 16092
    Re: blank LCD screen IR7200
    Did u check display contrast dial on the control panel to adjust it's brightness ?
    • Canuck
      Tech Specialist
      • 1711
      Inverter PCB for LCD display possibly..
      • jiongpao
        • May 2009
        • 413
        You might change the LCD screen and use back the touch panel if the adjustable contrast working good.
        • Canuck
          Tech Specialist
          • 1711
          Control panel inverter PCB...FG6-7738.......cheap...around 25 bucks
