Canon IR adv 6075
  • Nestopee
    • Feb 2018
    • 28
    [Error Code] Canon IR adv 6075
    Good day Guys, the machine gets to ready, immediately the start button is pressed the error 263-000 appears.
  • laitang
    • Nov 2012
    • 627
    Re: Canon IR adv 6075
    E263-0000: Error in Current Sensor reference voltage generation
    Check the connection between the AC Driver PCB and the Main Driver PCB (connector disconnection, open circuit, short circuit of harness).
    AC Driver side: J615, Main Driver side: J103
    Good luck!
    • rincoh
      • Feb 2018
      • 2
      can you tell me thats you change the AC DRIVE?
      • fchu5959
        Field Engineer
        • Jun 2010
        • 100
        Hi,
        It could also be the Relay pcb or the DC controller.
        Cheers
