Dark copy & print with small dark dots
  • yusuf mwaka
    • Aug 2025
    [Misc] Dark copy & print with small dark dots
    hi guy...........Please help, i have problem with canon ir 2202 when i print or copy it make Dark copy & print with small dark dots
    As you see on picture
  • Brian8506
    • 1667
    Re: Dark copy & print with small dark dots
    And what have you done so far? I would hope you looked at the drum first
    • yusuf mwaka
      Yes, i had clean drum but doesn't work.
      • Brian8506
        • 1667
        • teckat
          • 16083
          Cleaning the Photosensitive Drum
          If the surface of the photosensitive drum is soiled, wipe it with a flannel cloth coated
          with toner. (Do not use paper, lint-free or otherwise.)
          ---Do not dry wipe it nor use solvent.
          ---Further, never use drum cleaning powder.
          DRUM Bias is Shot ?
          Developing Assembly Bias ?
          GPR-6 DRUM====55,000 copies estimate life at 6% text coverage
          are u using Canon OEM toner and drum
          • Canuck
            Tech Specialist
            • 1713
            If the print has spots ,pull the drum unit out and see if the drum is clean after making a print. If the surface is dirty(should have a clean surface for next charging cycle),replace the drum unit. Drum count? Post a print with an image on it
            • teckat
              • 16083
              Originally posted by Trtet3
              The Dark Net Wiki is a great resource for anyone who wants to explore the dark web tor wikpedia. It has a lot of useful information on how to access the dark web safely, as well as guides on how to use various tools and services. There are also a lot of interesting articles on topics like cryptocurrency, hacking, and privacy. If you're new to the dark web, this is a great place to start.
              your post has nothing to do with copier help and or support
