ImageRunner C3480i Firmware and manual
  • TOPStech
    • Jun 2017
    • 4
    [Misc] ImageRunner C3480i Firmware and manual
    Just installed new drums and machine is stating "Install Black Drum" message. I understand I need firmware update. How can I obtain the firmware and how can I purchase a manual for same.
  • tech28
    • Jun 2013
    • 434
    Re: ImageRunner C3480i Firmware and manual
    Replace the T/B, have had them do that many times, just install transfer belt, it will be fine.
    • TOPStech
      • Jun 2017
      • 4
      Client does not want to spend money on ITB and through his own research wants me to upgrade firmware. Currently DC-Con is Ver. 48.01 and previous threads state it should be 61.00 to eliminate the need to detect new drum.
      • teckat
        • 16083
        How is a New/Old Drum unit identified
        This device does not have memory in the drum unit, when a new drum is mounted, the drum life counter value stored in the printer needs to be reset.
        The device detects old and new drum units, so that the counter can be reset.
        The detection is performed by the DC controller CPU monitoring the fuse detection signal.
        When the CPU detects that a new drum unit has been mounted, it outputs a fusing signal and blows the fuse on the drum unit. At the same time, the drum life counter resets to 0.
        1. Time of Detection: at power-on, after the front cover is open/closed
        Note:
        Do not replace drum units with new ones unnecessarily, in order to check function operations during service, etc. The device blows the drum fuse as soon as it detects a new drum unit and resets the drum life counter to 0. Even if the old drum is replaced immediately, the drum life counter will increment as a new drum unit.
        In Service Mode COPIER>FUNCTION>INSTALL >AINR-OFF invalidates drum initialization that is performed when a new drum unit is installed.
        Also, the fuse is not blown, as it would usually be after drum initialization is complete.
        This mode would be used to replace a drum unit temporarily in order to check image quality, for example trying to trace the cause of the problem.
        0: Initialization carried out for new unit. Fuse blown (Default)
        1.: No initialization for new unit. Fuse not blown.
        Further, this service mode should be set to [1] only when necessary for service. After the service is complete the setting must always be returned to [0].
        • TOPStech
          • Jun 2017
          • 4
          I replaced all drum units since they were all severely used, causing lines and background. Once the initialization of the drum units was completed, the message "install black drum" was displayed. I did do the procedure that you recommend to no avail. Many threads recommend a firmware upgrade and therefor would like to do that. I am a Sharp/Ricoh/HP/KonicaMinolta shop and am doing this Canon as a favor. I am simply looking for the firmware and a service manual.
          • darkocg88
            • Jan 2018
            • 63
            Check your messages Topstech.
            • teckat
              • 16083
              Introducing DCON v49.01 to Help Prevent Miscellaneous "Insert Drum Cartridge" Messages
              During the life of the ITB Unit, resistance against parts around the Primary Transfer Roller causes a decrease in the primary current at the drum detection sequence. This symptom may occur more frequently
              in a low temperature, low humidity environment.
              SERVICING:
              To address this symptom in the field, we recommend performing the following:
              Insert Drum Message.jpgTransfer H.V. PCB (HV2) Contacts
              Procedure:
              a. Clean the Transfer H.V. PCB (HV2) Contacts.
              b. Clean the Process Unit contacts to the main frame.
              c. Upgrade the DCON to v49.01 (attached with this Technical Publication).
              Note: To install DCON v49.01DCON v49.01, extract the .exe file, start the Service Support Tool v4.11Er or higher and
              browse to the folder listed below:
              If you have only one drum color message issue >>> look into this below issue
              imageRUNNER is displaying a message to "Insert Drum Cartridge" for black even after a new drum has been installed.
              Solution
              The problem could be related to a broken, loose, or missing drive drum coupling.
              In some cases the drum drive coupling was dislodged from the black drum drive shaft.
              This prevented the drum from rotating and caused the machine to display that the drum was not installed.
              • tech28
                • Jun 2013
                • 434
                If you put old black drum back in, message will disappear. Doesn't solve your problem, but, gets up and running until you replace transfer belt, even a used one will take care of that message.
