ImagePress C1 doing bizare faulty image
  • Liebendeinsam
    • Jun 2015
    • 12
    [Misc] ImagePress C1 doing bizare faulty image
    Hello.
    One of my C1s is doing the faulty print like in the images above:
    I don't have any clue in what is causing this, but in the area of the faulty image, I'v found that some of the granulation is losen and I'v tested with one magnet and only can be developer grains.
    I'v checked the module that have the developing modules, and found the normal dirty and cleaned it.
    One strange thing that I've found, is that the ITB in its surface has a tiny layer developer in its surface, but how this is going in there? Anyway, I've cleaned de ITB and its cleaner and other things, closed the machine, did the default preparations, and tested.
    But what is causing this faulty image? And from where is coming this dev. dirty that I found in ITB, in the prints?!
    One little thing that maybe not have linked to the problem is that the "ink buffer" is lagging (and some times don't) to deliver black ink to it's developer unit, but again I di not have any clues of what is doing this because if I manually rotates the deliver spiral I's function beautifully!
    For any questions, this parts is new:
    - ITB
    - Drum
    - Dev. K
    - Dev. C
    - All parts that do cleaning job
    - Fusion Bel
    - Fusion Tambour
    - Wires, and Plate Grid
    - All rubbers and vedants
    - All filters
    - All vital wires
    - Some mottors
    - All parts of K and M ink deliver
    - Image Transfer Roller
    - the system of residue removal and deliver to bottle as well.
    And the machine continues doing not so good prints
    My contacts here don't seen this king of problem before.
    Thanks for any advise.
  • teckat
    • 16083
    Re: ImagePress C1 doing bizare faulty image
    Bias Issue
    The Developing BIAS Input Assembly resides on the front plate of the P-Kit.
    When the Developer Units rotate and are positioned for development, the BIAS tab rubs against the Developing BIAS Input Assembly to receive the developing BIAS.
    Pics links of Bias Tabs
    Google Image Result for http://www.techsupport.cusa.canon.com/cd/12/resources/34482.jpg
    Google Image Result for http://www.techsupport.cusa.canon.com/cd/12/resources/34481.jpg
    • Liebendeinsam
      • Jun 2015
      • 12
      Originally posted by teckat
      Bias Issue
      I've cleaned the "FM2-2662-000" and did "(COPIER>OPTION>BODY>PO-CNT to 0)" and the problem is solved, I'v got the E061 after lots of tests and the change of Potential sensor.
      Now what?
      Notes:
      All developer from M dev module is gone why!? I'v fixed it.
      • teckat
        • 16083
        Originally posted by Liebendeinsam
        I've cleaned the "FM2-2662-000" and did "(COPIER>OPTION>BODY>PO-CNT to 0)" and the problem is solved. I'm not getting E061.
        All developer from M dev module is gone why!? I'v fixed it and now works OK.
        I'll try to use one Potential Sensor (FM2-2642-000) from one of the junk printers the I have here...
        Tanks. If u come to Iguassu Cataracts (BR), tel me, now you have one more friend.
        Thanks for the Invite
        Bias is the Glue that prevents Developer from just falling off the cylinder
        • Liebendeinsam
          • Jun 2015
          • 12
          Likewise the case "digitalpressvietnam" changing the drum solved the problem of granulation (one drum that is "new" 6 months, clean blue.... ).
          What in the hell caused this degradation on that drum?
          Now I'm getting E820-0003, this is a short circuit or something like, this comes and goes like a ghost, the electrical outlets is not giving volts/amps necessary (I'v just removed Drum module and inserted another one and configured all parameters).
          Jesus. I just want to recycle all those old machines, buy new ones or rent, stop making myself the maintenance and focusing in other things!
          Finally today we buy one printer from konica, less robust but.... works fine.
          • teckat
            • 16083
            Make sure the Primary Corona assembly is mounted correctly.?
            The E820-0003 error code with this subcode refers to FM7 ITB Cleaning Cooling Fan.
            This fan provides cooling of delivered paper. The fan connects to the Side Driver PCB at connector J3404 pins 4, 5 and 6.
            You can also test the fan via the Parts Check in service mode at COPIER>FUNCTION>PART-CHK and set FAN to 7.
            E820-0003 is related to an ITB cooling fan (FM7) error.
            The machine warms up fine with FM7 running at 1/2 speed (12V) but, errors out when FM7 goes to full speed (24V) during the copy process. If measured you may read 23VDC at full speed. ?????
            Workaround :
            In some cases, the primary corona unit was arcing and caused the error code. Inspect the primary corona assembly and ensure that there are no arc marks on the primary corona blocks and that the tag ends of the charge wires are trimmed.
            Also
            This is an ITB cooling fan error for FM7.The fan will turn on and run at low speed at start up, but will error out before the copier finishes warming up. After replacing the Fan, Side Driver Pcb, DC-Controller, cutting tie wraps, and checking continuity on the wire harness the error still remains.
            Workaround :
            When checking voltages to the fan, the fan should run at high speed when the copier is first turned on and 24 volts should be present on connector J259 pin 3 shown in the diagram below.
            When the fan slows down to low speed, 12 volts will be present on the same pin of connector J259.
            In this case, there was only 12 volts when the machine was turned on, and the fan ran at low speed all the time. Something was taken down the 24 volts. After removing 24 volt loads one at a time from the Side Driver Pcb, it was discovered that unplugging the Primary Corona Wire Cleaner Motor caused the 24 volts to return to the fan and the machine booted up normally. In this case the Primary Corona Wire Cleaning Motor was taking down the 24 volts.
            The Primary Corona Assembly was replaced, to resolve the issue. The primary corona Cleaner Motor part number is FL2-0991-000 and the Primary Corona Assembly is FM2-2496-000.
            Pic link
            • Liebendeinsam
              • Jun 2015
              • 12
              teckat.
              The E0820-0003 is a random short circuit relationed to something in the dev./drum drawer. I'v just opened inspected and closed. Now it's running.
              This C1 that I was fixing has this bad behavior some times.
              Without you I'll never have think that is the Drum the problem.
              Tanks man, and come to Iguassu Falls one day visit. I'll do to you a free guidance about the tourism locals.
              • teckat
                • 16083
                teckat.
                COLOR HAND.jpggood luck
                • MARCIO ANDRE
                  • teckat
                    • 16083
                    Bands
                    Do you get a double band on Large Paper ( 11x17)- A3 size
                    When Potential Control is turned off, is the banding is resolved.
                    --Check your Potential Sensor Connector.
                    Potential Sensor PCB Assembly (includes the Harness)
                    (FM2-2642-000)
                    Crossfeed Bands----inspect/ replace
                    Laser Scanner Assembly (FM2-6066-010)
                    Does the starter to toner mixture feel grainy to the touch for Copies and Prints
                    You may also have a Bias Issue
                    Developing BIAS Input Assembly resides on the front plate of the P-Kit. When the Developer Units rotate and are positioned for development, the BIAS tab rubs against the Developing BIAS Input Assembly to receive the developing BIAS. It is possible the machine could experience loss of colors intermittently and therefore needs replacement. The part number is FM2-2662-000.
                    • teckat
                      • 16083
                      To add on, after checking old notes.
                      U need to double check the ITB, especially if you replaced the belt or entire unit.
