ir2004N without counter display
+ More Options
Posts
  • Blues Guy
    • Aug 2009
    • 216
    Good day guys,
    I have a iR2004N problem started with main controller P.C.B the network port is not working.
    Hence I have order a new main controller thru Canon and replaced it to this machine well everything is back working fine it can print/copy & scan. The only problem now when I press the counter check button on the panel to check the counter display was disappear.
    Do you guys encounter this problem before ? Where do I set it back ?
    How to enter service mode for this model ? I don't have the service manual to refer to. Thank you
    Re: ir2004N without counter display
    Originally posted by Blues Guy
    Good day guys,
    so you swapped main board Without having a service manual? thats why your counter is missing. you didn't init the board properly
    • roho
      • Mar 2009
      • 844
      I believe you get into service mode the usual way, if that doesn't work try hitting the 2 and 8 keys consecutively, not simultaneously. Did you have any secondary pcbs on the main controller or memory to swap over? Perhaps flashing the firmware may help.
      • teckat
        • 16083
        Good day guys,
        First re-check your connections on pcb.
        Did u re-input the Main Pcb settings from original spec sheet ?
        SERVICE MODE
        imageRUNNER 2204N / 2004N / 2004
        Press HOME Key
        then_Press RESET Key
        then_Press BACK Key
        then_Press Home Key again
        (one press on each key)
        Brings up Service Mode Screen Menu
        not sure if this model has below
        Copier > Option > Counter
        or
        Check settings under Copier > Option > User > CNT-DSP
        • Blues Guy
          • Aug 2009
          • 216
          Thank you teckat. I will check it out
          SERVICE MODE
          Press HOME Key
          then_Press BACK Key
          [ATTACH=CONFIG]39405[/ATTACH]
          or
