Canon ImagePress C7000 E020-492
  • markdmt
    • 76
    [Error Code] Canon ImagePress C7000 E020-492
    This is just for informational purposes no response needed. i will post in case someone has a similar issue or i forget about it.
    We had a client with a Canon ImagePress C7000 E020-492 code . The things we changed were the drum, the developer station, most of the process station, the DC 1-2 board. Also cleared the DC con, cleaned out the auger feeding tubes and hand cranked toner through it. the charger we had new grid and wire on it. The issue we were having is after installing new developer AY and inputting ALF-K value everything passed and setup. once we started running the density of black kept going down until it would code. If we put some toner into the black sub hopper the DEN-S-K and DEN-K values would start moving in the right direction. We fixed this by putting a new charger in the Black position. we swapped with Cyan and the Cyan started to behave the same way. we think the charger must have been shorting onto the drum somehow and creating a weird issue. a lot of work for a cheap part. we haven't been changing out the charger AY hardly ever and i guess having this experience we may start to follow the recommendation of the QA kits and replace those housings at the recommended interval.
  • teckat
    • 16092
    Re: Canon ImagePress C7000 E020-492
    Macgyver.jpg "MacGyver is Back"
    • alaa55
      • Nov 2014
      • 5
      Re: Canon ImagePress C7000 E020-492 Lower limit error in developer density DISPLA
      Lower limit error in developer densityDISPLAY>DENS>DENS-S-Y/M/C/K is -5 % or less for 3 times continuously
      • teckat
        • 16092
        The manual is only a point direction to start.
        Many factors contribute to Density Issues.
        • alaa55
          • Nov 2014
          • 5
          What is the reason for this and Canon ImagePress C6000
          Macgyver.jpg "MacGyver is Back"[/QUOTE]
          • khattab.al.masry
            • 212
            I would be to my contribute to be useful:
            i faced the same error but with other sub code (E020-0192)
            that related to yellow color so we checked the following readings:
            1-level 1----copier----display----den-y was as default reading
            2-level 1----copier----display----window-y was as default reading
            3-level 2----copier----display----dens-s-y was not with default reading (300:500) it was 950
            i run drum reset the default reading for DENS-S-Y reads 350
            so the the case is solved
            i hope to be helpful.
