Windows 10 Scanning
  • repeatcopiers
    • Sep 2008
    • 591
    Windows 10 Scanning
    I have several customers that have just purchased new computers loaded with Windows 10 and for some reason when trying to connect the Scan function, the copier can't see the computer. We have verified the user name and password of the computers are correct. We have other customers that have computers loaded with the earliest version of Windows 10 and those seem to work fine. I searched other post and went in to turn off password protected sharing but still no change. Anyone else having this issue or know the fix?
    • 30194
    Re: Windows 10 Scanning
    Use filezilla server scan via ftp. On windows 10. Windows. Or scan to email
    you have to add filezilla to firewall
    • guitar9199
      • Sep 2016
      • 1100
      First thing to do is go into Network and Sharing Center, click your network adapter, go into Properties/IPv4/ Properties/Advanced/WINS and make sure it's set for "NetBIOS over TCP/IP". Then go into your Firewall settings, and for Inbound Rules, make sure "File and Printer Sharing", and "Network Discovery" are all enabled.
      ...if that doesn't work, you may need to set the computer up with a static IP address and create the file path using that instead of the name of the computer.
      Works great on desktops that never leave the office... Laptops? Those can be troublesome.
      • apoxi
        • Nov 2015
        • 45
        Which machine?
        • niyaskarimba
          • Sep 2014
          • 110
          Originally posted by apoxi
          Which machine?
          we are also facing the same issue kindly advice with solutions
          Thanks in advance
          • niyaskarimba
            • Sep 2014
            • 110
            Sir,
            Most of the clients only required SMB scanning only, kindly advice possible solutions to resolve SMB scanning issues in windows 10.
            • repeatcopiers
              • Sep 2008
              • 591
              Which machine?
              I have several customers with this issue. Advance C5240, Adv C2020 and Adv C5035
                • 30194
                Originally posted by niyaskarimba
                Sir,
                Do to update from Windows SMB1 has been disabled. Most machines Can't scan via smb2 or 3 without a firmware upgrade or do to the model can't support smb 2 or 3
                scanning. Never had a client yet that refused scanning via ftp to desktop.
                Or use scan to email
                Microsoft to Disable SMBv1 in Windows Starting This Fall
                • Cipher
                  It's not easy being green
                  • May 2006
                  • 1309
                  • Microsoft disabled SMB v1 by default in the latest builds of Windows 10.
                  To be able to use the newer versions of SMB (v2 and v3) you will need to update the MFDs firmware to add support.
                  (Older models may not receive updates).
                  If security is of no concern you can currently re-enable SMB v1 in Windows 10 but it's NOT recommended.
                  (Microsoft will be completely removing this option in the next major update).
                  • apoxi
                    • Nov 2015
                    • 45
                    You must upgrade the special firmware!!!
                    For ADV52XX series is special firmware v46.68.
                    Look pdf file. Also have special firmware for ADV50xx and C20XX
