Fixing assembly for iR-ADV 4225i - broken
  • photopetrica
    • Jul 2025
    [Misc] Fixing assembly for iR-ADV 4225i - broken
    Hello guys
    I've just changed the entire Fixing Assembly Unit P/N FM4-9737-010000.
    Now I look at the broken unit, and I ask myself: can only the broken part (the black film) and the pressure roller be changed?
    Can someone indicate me the part number of the above parts?
    Thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Fixing assembly for iR-ADV 4225i - broken
    FC9-8974-000 Lower Pressure Roller
    FM4-7900-000 Fixing Film Assembly 120V
    FM4-7901-000 Fixing Film Assembly 230V
    • photopetrica
      Thanks for your quick answer. I'm OK with pressure roller, but changing the entire fixing film assembly will cost almost as the entire fixing assembly main (240 EUR+VAT).
      I want to change only the black film which is part of the fixing film assembly. Can this be possible?
      Do you have a suggestion for a good online store (EU or outside) to buy these parts?
      • zoraldinho
        • Mar 2008
        • 5007
        Canon sells only the entire unit. If I wan't to replace only fuser film sleeve, I usually bought a compatible one.Some Katun's turned out to be okay.
        There are quite a few of them online, for example, below.This link is only a sample and i do not guarantee it's okay.
        Fuser Fixing Film Fuser Film Sleeve For Canon iR 2520 2525 2530 2535 2545 iR ADVANCE 4025 4035 4045 4051 4225 4235 4245
        • photopetrica
          @zoraldinho
          Great! That was the answer I was looking for!
          Do you have any idea about the number of copies with this "non-Canon" film? The original last about 180k.
          Will you be so kind to help me with the same issue for "FM1-P255-000 Fixing Assembly" for iR-ADV 400?
          Thank you.
