E061-0003
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    [Error Code] E061-0003
    Has anyone any experience fixing this error code on a iR-ADV C70xx?
    K Drum life is at 357%
    Checked the main charge and pre-charge units.
    Checked the terminals at the rear of the machine.
    Replaced the HV PCB.
    Last thing I tried was a used K drum unit from a loan machine which was also pretty worn, and that did work for a week or so but now the same error has returned.
    The original service call a week or so ago was for partial/intermittent black prints, which then turned into completely black prints, then error code occurred.
    Any idea?
    I do have a new drum I can try, but I'm told they should have no problem stretching up to 600%.
    Re: E061-0003
    Any idea?
    sounds like a drum grounding issue.
    think back to the days of a monochrome HP Printer.
    • Canuck
      Tech Specialist
      • 1713
      Re: E061-0003
      Its a Vd potential control error. Try replacing the primary charger. I would replace that black drum also if its count is that high...just asking for trouble. 600%?...yes...if you want garbage quality. That's an OPC drum...not ASI that lasts forever. It wont charge properly on long runs if it is weak.
      • Cipher
        • May 2006
        • 1309
        Re: E061-0003
        Thanks.
        We have a bunch of them being replaced in a month or so we are just trying to keep them running without fitting too much.
        But as normal they are fighting us all the way, I've probably had more problems in the last couple of months than we have had in the last 6 years. But they are old, worn and tired (like my knees).
        [EDIT] K drum unit service fixed it.
        • JPiek
          • Oct 2014
          • 435
          Re: E061-0003
          Thanks.
          NEVER say out loud the copiers are going to be replaced when your in the proximity of them ...
          I learned that from a couple of cars I had
          Johan
