Imagerunner Advance 4245 Auto paper selection message for print jobs.
  • Desert Rat
    • May 2008
    • 1089
    The customer reports that they get a message from the machine to select
    the correct paper. All they do is select a tray and it takes off and prints.
    But they have it all set for auto select. I went through the settings under
    additional functions and set it to what I thought would fix the problem.
    And it seemed to do that for just one person. Well another person
    just started having the same problem.
    Has anyone else seen this? My gut feel is a driver setting? I just sold this to them about
    4-5 months ago. It seems odd that it would just now surface.
    I'm going back Monday to try and find something.
    Any suggestion welcome.
    DR
  • teckat
    • 16092
    Re: Imagerunner Advance 4245 Auto paper selection message for print jobs.
    This probably doesn't apply,
    If Paper Drawer Auto Selection On/Off] is set to 'On' for a paper source, depending on the paper type, automatic paper selection may not be performed.
    Printing from PC
    Note:
    All paper types available on the machine are eligible for use with Automatic Paper Selection if they match the paper types specified on the printer driver.
    • Desert Rat
      • May 2008
      • 1089
      Thanks Teckat, I will check the driver settings tomorrow.
      DR
      • Desert Rat
        • May 2008
        • 1089
        I turned the paper size override to "on".
        That seemed to take care of the auto selection concern. Now they don't have to walk in to the printer and select a tray.
        Then one of the secretaries mentioned that she could not get collated sets while printing.
        I changed one of the printers settings the output setting I set to collate. Then she selected collate and sent
        the job over. It still did not collate that job.
        I'm thinking the IT tech needs to reload the driver or use a different driver?
        I'm not sure, I do not do IT work.
        Is there another place to look? Or setting I need to change?
        DR
        • teckat
          • 16092
          DR
          what print driver ??
          PDL Support
          Standard: UFR II
          Optional: PCL 5e/6, PCL 6, Adobe PS 3
          does her print driver show the 4245 w/G1 Finisher ??
          UFRII
          • Desert Rat
            • May 2008
            • 1089
            Teckat,
            I am not an IT guy so I get lost easily here. But I will try to get the info requested and pass this along to their IT guy.
            DR
            • teckat
              • 16092
              Teckat,
              DR
              If sending collate jobs issue is from one persons desktop PC - there lies the issue
              • Desert Rat
                • May 2008
                • 1089
                It started with the receptionist. It would request her to select a tray when hers was set to auto.
                I made sure all the auto feeding was enabled. They are using LTR in three trays. I had to mark
                one "custom" just for her.
                Next one of the secretaries came up with the same problem. I changed the paper size override to on
                and set tray one back to LTR. Now they could both just print to auto tray.
                As I was leaving the receptionist said she was having trouble getting it collate this job.
                So I changed the output to collate and made sure she changed hers to collate.
                It still did not collate that file.
                The office manager is going to get invovled next to see if she missed something. Then she said she would
                call their IT guy.
                I told her I would be happy to forward any info I get from this board.
                I will double check to see if the finisher appears.
                Is there a prefered driver for this machine?
                DR
                • teckat
                  • 16092
                  call their IT guy.
                  DR
                  PDL Support
                  Standard: UFR II
                  Printer Options***
                  PCL Printer Kit-AY1
                  PS Printer Kit-AY1
                  Direct Print Kit (for PDF/XPS)-H1
                  UFR II standard.
                  http://s7d9.scene7.com/is/content/Li...rochurepdf.pdf
                  imageRUNNER ADVANCE 4245
                  https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/multifunction-copiers/imagerunner-advance-4245/imagerunner-advance-4245
                  • Desert Rat
                    • May 2008
                    • 1089
                    I will post the results when I get them.
                    DR
