anyone pls help, Mr Teckat pls help..
  • nardinard
    • Oct 2014
    • 12
    i have a situation canon ir5075
  • teckat
    • 16083
    Re: anyone pls help, Mr Teckat pls help..
    [ATTACH=CONFIG]39583[/ATTACH]
    U mean solid black line ?
    Does it move down copy ?
    Is that a glass copy ?
    Check ?
    Corona Wire
    Dust laser glass
    • nardinard
      • Oct 2014
      • 12
      Check ?
      Corona Wire
      Dust laser glass
      Yes, its solid black line,
      From the glass
      And pls check the table, its abnormal result
      • teckat
        • 16083
        [QUOTE=nardinard;603812]Yes, its solid black line,
        From the glass
        And pls check the table, its abnormal result ???????
        what have u checked ???
        Corona Wire
        Dust laser glass
        Optics
        Drum surface
        does it move ?
        are u a tech ??
        • nardinard
          • Oct 2014
          • 12
          [QUOTE=teckat;603846]
          From the glass
          Corona Wire
          Dust laser glass
          Optics
          Drum surface
          does it move ?
          are u a tech ??
          Already check
          Primary and transf corona is good
          Laser ok
          Optic ok
          Blade ok
          Drum ok
          Belt is ok
          But got noise in the back side like krek krek
          • teckat
            • 16083
            [QUOTE=nardinard;603859]
            Already check
            Laser ok
            Optic ok
            Blade ok
            Drum ok
            Belt is ok
            printing from PC is ok ??
            • roho
              • Mar 2009
              • 844
              Guessing it doesn't matter if it is a print or copy if that noise means anything. I think the solid line may be a arcing situation. Poster says the coronas are ok, but has he looked at them only or swapped? Poster may want to check along the process tray, especially the block assembly where the transfer corona couples in. I have seen some of them crack and cause various symptoms. The block will be at the very back of unit one.
              Let us know if you have swapped out any corona assemblies, or just a visual inspection. Best to swap out as eye test may reveal nothing.
              • nardinard
                • Oct 2014
                • 12
                already change primari n trans wire
                change cleanin blade
                BLOCK ASSEMBLY TRANSF CORONA BROKEN AND I USE SOME ADHESIV TO FIX IT
                and last i change 1 block unit gear drum but noise still come
                can it be from 1 of motor or gear for roller left door make that noise and paper be late come to drum?
                ps. noise didnt come when unit warmn up, only come when printin
                • nardinard
                  • Oct 2014
                  • 12
                  [QUOTE=teckat;603867]
                  no, is some condition
                  • roho
                    • Mar 2009
                    • 844
                    Replace that "fixed" block with a good one, who knows what the properties of that adhesive are. Start there first, and clean the entire transfer/sep corona area out on unit 1to remove any build up of old toner and grease. I don't see a drive issue causing this, you would likely be getting jams. try new corona assemblies if possible, not rewired ones as well. Not a easy issue to peg, need to completely eliminate things, so rewiring a corona assembly may be just putting a problem back in. Replace the block!
                    • nardinard
                      • Oct 2014
                      • 12
                      Already replace the block but solid black line still show up
                      • COPIERTEC ASSOCIATES
                        • Aug 2011
                        • 279
                        Had a similar case and the problem arose from belt that drives the drum and dev unit which jerks and causes the black strip.
                        Remedy;Open the rear covers,access the belt, clean the dev drive clutch,disamble the dev unit to make sure it moves smoothly,look at the teeth of the drive belt for possible wear and replace if worn out,check on the tension spring in case it is loose and replace,check on all gears that drive that system to prevent the jerking.
                        • techandtrader
                          • Jun 2016
                          • 335
                          Sure looks like a stuck block to me. Has he forced them all to the front or rear and unplugged wire cleaning?
                          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                          • Canuck
                            Tech Specialist
                            • 1713
                            This machine charges the drum positive and laser writes black. If primary cleaner is stuck(which they do all the time on these), no charge on drum in that area. Its like laser wrote there(discharge to create latent image)...black line
