What to check if machine will not Browse the network when registering new Scan Button
  • techandtrader
    • Jun 2016
    • 330
    What are the things to check for and change to enable browsing from the One touch. It's easier to set the scan folders up from here.
    What are some of the things you change to enable this?
    Can it quickly be done?
    What will cause a machine to lose this ability?
    thanks!
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • dan7777
    • Dec 2012
    • 680
    Re: What to check if machine will not Browse the network when registering new Scan Bu
    thanks!
    I think it is easier also. I find out there is usually something blocking it. Have found Norton antivirus, avg antivirus, firewalls, Norton internet security among some. Also need to enable file sharing. Sometimes I have to turn the call over to our network guy who has never shared much of anything with me. I think he also finds it with a host search or another way. Other than making sure it has the dns servers listed I am not sure. Maybe someone with more network experience will let you know. I know windows 10 adds other things to look for. Most users are not even aware of any firewall programs on their computer I found out. I look and turn off things then go look to see if it will browse to the scan folder or even the computer. Usually if you can browse to the scan folder it works for me.
    • techandtrader
      • Jun 2016
      • 330
      Exactly but there should be a checklist somewhere. I ask because it really is a big list. I don't think the master computer stuff applies anymore esp since XP is gone. I would love to see a list for troubleshooting this problem. Thanks for posting.
      • Service@PRT
        • Oct 2016
        • 181
        thanks!
        I've encounter this things many times with our client. Most of them are using windows 10 and some like 2 to 3 pc are not getting into scan to folder settings in one touch, even we can browse them on the networked pc. Can see also their respective shared folder but not on machine like 5030i, 5051, 5045. Still wondering because all the pc are installed by us and all the software on it and configure all same. I just want to know the answer as well on these matter.
        Sent from my HUAWEI VNS-L21 using Tapatalk
        Every day of life is a learning process...
        Just make sure you are open in all aspects of comments.
        • DFM914
          • Jun 2010
          • 73
          You can also use "Search Host" and use the computer name or server name. Once you click on the destination PC, it should prompt you to enter credentials. This works when you Browse but get no results.
          • JPiek
            • Oct 2014
            • 435
            Isn't browsing also part of SMB v1 ? So the Copier will default to that ?
            Johan
            • Jerrygbs
              • Dec 2008
              • 193
              Canon has come out with patches because of windows 10 turning off smb1
