D1150 border erase adjustment
  • copydocinc
    • Mar 2015
    • 263
    My customer is complaining that the blank border is to big and can I adjust it to be smaller or no blank edge at all.
    I can not find any adjustment to reduce the blank edges at all.
    The edges are about 1/3" blank on all 4 edges.
    Any help would be great.
    thanks
  • teckat
    • 16083
    Re: D1150 border erase adjustment
    thanks
    Borderless Printing (Windows)
    Canon Knowledge Base - Use Borderless Printing '('Windows')'
    Canon Knowledge Base - How to Perform Borderless Printing - Windows
    • copydocinc
      • Mar 2015
      • 263
      Sorry, I should have made it clearer.
      I need to know if there is a way to reduce the blank edges to smaller or no blank edge while copying.
      It is there when using the doc feeder or on the glass.
      • teckat
        • 16083
        customer wants to run full bleed
        what are they copying ??
        Copy Area
        Item Size
        left margin 5.0 mm
        right margin 5.0 mm
        leading edge margin 5.0 mm
        trailing edge margin 5.0 mm
        PCL Print Area
        Item Size
        left margin 4.2 mm
        right margin 4.2 mm
        leading edge margin 4.2 mm
        trailing edge margin 4.2 mm
        Function List
        Key Item Key Item
        [1] leading edge of original [6] trailing edge margin
        [2] left margin [7] non-scanning area
        [3] effective scanning width [8] scanning range
        [4] right margin [9] trailing edge of original
        [5] leading edge margin
        #PRINT
        #PRINT NUMERIC
        <053: Margin adjustment at the leading edge of the copy>
        Adjust the margin at the leading edge of the copy. Increasing the value makes the margin
        at the leading edge larger.
        <054: Margin adjustment at the trailing edge of the copy>
        Adjust the margin at the trailing edge of the copy. Increasing the value makes the margin at
        the trailing edge larger.
        <055: Margin adjustment at the right edge of the copy>
        Adjust the margin at the right edge of the copy. Increasing the value makes the margin at
        the right edge larger.
        <056: Margin adjustment at the left edge of the copy>
        Adjust the margin at the left edge of the copy. Increasing the value makes the margin at the
        left edge larger.
        • copydocinc
          • Mar 2015
          • 263
          They copy pages with print close to the edges of the page. Just close enough that 1/2 the words are cut off.
          I am assuming these adjustments are available to perform in tech mode or service mode.
          How do I get to service mode on this model? So I try these adjustments.
          • teckat
            • 16083
            Press "Menu". Press "2", "8", then "Menu"
